How to remove gas cap cover
Copy & Paste Moderator
Here is a quick write-up on replacing the stock fuel door with a billet 2000-2005 Eclipse fuel door:
https://ls1tech.com/forums/showpost....1&postcount=36
In there it gives an overview of removing the stock fuel door.
you have to remove the black cover in there first by unscrewing it. then you will have to drill the rivots taht hold the door in there. and simply pull it out. you can either re rivot it back in or you can put some screws in it to hold it. hope that helps. and why isn't the shop removin it for you??
