Binding in right rear/hub/axle
2000 Camaro SS 115k. Only when I accelerate hard I feel a bind in the right rear. Maybe you could describe it as slipping. What is it and recommendations on parts. Cost?
Could be your clutch plates in the carrier slipping. Drain fluid and fill with new. Dont forget limited slip additive. If it needs clutch discs this wont fix it however it may make it better.
