Does anyone know how to tell what is draining my battery
Just as the title states, I have let my 98 Tahoe sit for 10 days, at the beginning I put a BRAND new battery in, and came back from vacation and the car was totally dead. Does anyone have a way to tell what is draining my battery? Thanks!
Just because that battery is new doesn't mean its any good. Take it and have it checked.
You wouldn't be the first... or the last one to buy a new battery that wasn't any count.
If the battery checks out "OK" then look for a short. Or the alternator could be bad...
I hate searching for shorts.....
I'll look for socks though.
If there are aftermarket items, I'd look at those first (happened to me and and a trunk relay that was always on). To isoloate the draw, you hook up a amp meter in between the negative battery post and battery (must disconnect cable and have it run through the amp meter, or use one of the clamp versions and go around cable). Once you see the draw, start pulling fuses until you notice a drop and that will tell you what item could be the cause. From there, it's a matter of looking at wiring and the device creating the load as a cause.
i was pretty much just gonna say what eddie said, but if you don't have an amp clamp-you can use a mulitimeter an just set it to amps-shouldn't be more than a few amps anyway and just check inside and pull fuses till it drops.
