p0410 how do i get rid of this
This code has come on and i clear the code and will run the car for a couple startups and several miles and then the code keeps coming back... Where do i start and what are all the options to fix it?
If you're stock look up the code for your year at geatchatter.com for diagnostics, could be a few different things. It's a secondary air code so it's fine to drive. First thing I'd check is the AIR PUMP fuse.
what is the little round thingy on the back of the intake called. Are you talking about the thing where the air pump hose connects to then branches off another hose and also has a vacumm hose connected to the top?
