narrowest rear?
narrowest rear?
dont get many responces in the axle section so-->
- whats the most you can narrow a rear end before you have the change the backspacing from stock rims???
- can stock rims fit without rubbing on an axles 1.5inches shorter (on each side, 3inches overall)???
- can 1inch spacers on each side work without rubbing???
It would be real close you would definatley have touse spacers bc there is maybe 2 inches between the rim and car and then if you are running 275's you will for sure be rubbing the car 315's rub with the stock axle width
