Seals for ls6 intake mani
Well it seems I can't get that peice, so another question to ask. If I were to just buy another O ring the same size, would I run into problems if they are different strenghts? Like, rubber vs whatever? There isn't too much pressure I believe in the intake mani, so I don't think this would cause a leak? Or am I just off, and would be better off buying another mani
LS1Tech Premium Sponsor
^^I think that's the small seal for the MAP sensor itself. He's looking for the larger O-ring that seals that piece in the rear of the manifold that the map sensor slides into.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Yea, Matt tried to help me out yesterday, but unfortunatly nothing. I also called my local GM store, and got nothing still. Thanks for the help anyway Matt, I really appriciate it.
Anyone know if any kind of O ring will work, or does it have to be a specific material?
Actually we took some silicone seal, and just layered it carefully, fixed the oring with it, then once it was snapped back in place, a little more silicone around it, and wipped away any excess. I'll hopefully get around to putting it on this weekend, along with my new shifter, so we shall see. Thanks for all the help guys. If it doesn't work, I'm just going to save my money for a new FAST 92/92.
