knock retard EVERYWHERE after sensor swap.
OK, some of yall might have seen my thread where I was having idling issues, etc. Got that squared away. But via hptuners, I have Knock retard EVERYWHERE, 5* in reverse, 12* at part throttle etc. hit it from 80-140, NO KNOCK, there was one spell of .8* for less than half a second.
- im taking the car to get tuned friday, but damned im kinda worried I have other issues.
Did you use the same style sensors that come out, or did you try to "upgrade"? The '98's had 2 types of sensors installed from the factory. On one type, the connectors looked like a "bottle nipple" and the other type just used a clip. I had the infamous '98 knock retard problem and I simple replaced the sensors with exactly what came out of of my block and my knock retard problem was solved. I had the "bottle nipple" sensors. I didn't try swapping the harness to switch over to the clip style sensors. After I replaced them, my problems were solved.
...If you swapped sensor styles, I'd go back to what you had orignally and just get a new pair...
