Intake Manifold Question
I pulled 385RWHP at Cartek back in February. I have 5.3L Stage II Heads 2.02 valves, titanium keepers, chromoly pushrods, cam (220/224 560/564 114LSA), Hooker LTs, Carsound cats, SLP Lid, Thunder Race MAF ends, SLP CAI, 3" mufflex Ypipe, and Loudmouth. I still have an LS1 intake and no pulley. How much HP do you think is still left in my setup if I was to get an ASP Pulley and the LS6 or new LSX intake? The heads were ported by the Vette Doctors.
Thanks
Joe
Thanks
Joe
Re: Intake Manifold Question
Ls6 should put you over 400 and the pulley is debatable some have seen 0 on a dyno others have seem as much as 10. But none the less it should hit over 400rwhp with the 2 mods easy.
Nate
Nate
It was before everyone started doing the reverse cams that I had this stuff done. I just went with whatever the Vette Doctors said to do. I wanted a cam that wouldn't take away from drivability since it is my daily driver.
Joe
Joe
LS6 intake should bump you over 400 easy, and the pulley generally is good for 5-10hp as well. I've seen more guys pull hp out a pulley then not. Its definitely a mod I'll be going for. When I get my car......
