Need Advice
Need Advice
just wondering if im goin in the right direction with my build
im getting ls2 heads, an ls2 intake manifold, 90mm throttle body, 36lb 380cc fuel injectors, i havent picked out which headers im getting yet, and ive been searching for 3.73 gears.
im in japan, and i get back to the states in july, i have someone to do the work on the car but im kinda stuck on what to buy. i plan on eventually putting a turbo on the car but nothing too extreme, i would like to have it be a turbo DD in the near future.
no headers... buy some 317 heads.. no reason to get that big of an intake side.. a simple ls6 intake and ported TB will do just fine.. get a fuel pump.. if you want a cam on a budget get an ls6...
just search man..
and keep in mind.. if your doing N/A or nitrous that is a COMPLETE different setup and route than a S/C or turbo car.. 90% of the parts will be different.. and some will matter more on each build where some might not have to be touched..
no problem man...
also, here is some good reads..
https://ls1tech.com/forums/forced-in...t-up-faqs.html
https://ls1tech.com/forums/forced-in...turbo-faq.html
https://ls1tech.com/forums/forced-in...induction.html
