crank sensor
Old 01-26-2009, 04:25 PM
99LS1Bird's Avatar
Default crank sensor
from a cold start my car will crank run for about 5 minutes than die and it wont start again till the car has been sitting to a good 30 minutes to a hour is it a crank sensor causing it?
Old 01-26-2009, 04:57 PM
2001NBMZ28's Avatar
Why do you suspect the CKP? Throwing any codes?
Old 01-26-2009, 05:14 PM
99LS1Bird's Avatar
no no codes thats about the only thing i can think of
Old 01-26-2009, 06:24 PM
SS1875's Avatar
Have you checked fuel pressure?? Changed fuel filter lately?? Pump priming and sound okay at start up??
Old 01-29-2009, 02:22 AM
5.slow99's Avatar
a friend of mine had a problem similar to that a while ago and believe it or not was something as simple as the fuel filter was horribly clogged and the line where it was connected was crimped, so look there
Old 01-29-2009, 08:37 AM
Kikaofazz's Avatar
I just went through Crank sensor problems. It started as a backfire under WOT. It led to me driving between 10-15 minutes before the car would start to sputter, throw SES codes & then die. It would throw 2 codes: P0335 & P0336. It would take about 30 minutes before it would start again.
