question about thermostat on an 04 or 05 ls1 motor
Old 01-27-2009, 10:54 AM
bigfatls6's Avatar
Default question about thermostat on an 04 or 05 ls1 motor
My car had a new engine installed in it at the dealer back in 2005. I figured it was the same as the 2002 ls1 that came in it but I already found out that I was wrong. It takes the later model head bolt. I found that out the hard way when I bought my head studs and then had to get another set of the later model ones like the ls2 uses. I want to order a 160 thermostat but don't know which one to get and I don't want to order the wrong one. I know the later ls engine came with a different water pump where the thermostat wasn't made into the housing. Any one know which one I would need?
Old 01-27-2009, 08:08 PM
S10xGN's Avatar
IIRC, 1997 to 2004 had a one-piece t'stat/housing, the 2005+ units had a removeable t'stat like the Gen I & II smallblocks...
Russ
Old 01-28-2009, 04:32 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
What is the serial off the engine?
Old 02-01-2009, 05:52 PM
blubox's Avatar
My friends 04 GTO had the removable one..just FYI. I know because I replaced it for him.
Old 02-02-2009, 05:00 AM
toothdoc's Avatar
It sounds to me like you have an LS2 thermostat like I have on my LS6. The good news is that they are less expensive than the ones for the original LS1 engines.
Old 02-02-2009, 12:22 PM
bigfatls6's Avatar
Where would I find a serial or casting number on the engine block thats visible?
