Intake questions??
Intake questions??
What are the big differences between the ls2 and the ls6 intake manifolds. I was also wondering what the different part numbers are for both of them. Thanks
Biggest difference is the LS6 is 75mm and the LS2 is 90mm, also the MAP sensor locates in the rear of the LS6 while the LS2 it is in front and needs a wire extension to use it. The fuel rails required are different as well.
