LS1/Vortec Intake swap
I have a 5.3 Vortec and I am swapping an LS1 intake onto it. I heard there are cooler lines below the intake that also need swapped. I'm having a hard time finding the LS1 intake cooler lines, can someone point me in the direction I can find those and how much I am likely to pay.
Thanks
Thanks
LS1Tech Sponsor
if you are doing that, and going from the spider style coolant tubes, you need to get the caps for the back as well, and 4 gaskets. use the stock bolts.
front crossover tube
rear caps
you will need 2
and the gaskets you will need 4 of them
rear caps
you will need 2
LS1Tech Premium Sponsor
If you're running the truck accessories, I believe you have to do something about the idler near the top/drivers side as well. Check out the truck forum, but someone has an easy relocation kit for this swap and that makes it nice.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
