True Dual Setup Question
I'm am purchasing a true dual exhaust system consisting of hooker LT's, 3" pipe, x pipe, and spintech mufflers. I have several knowledgeble friends with ls1's who say this is a good setup but i would like some of my ls1 tech buddies opinions. Is this a good setup for a basically stock 98 ls1? How much is this going to reduce my ground clearance and where should i expect to see power gains? If u have any knowledge of true dual setups please inform me because i am not fully educated on their functionality. I have a lid and all the free mods. Feedback needed! Thanks!
Re: True Dual Setup Question
that is a good set up. I have the exact same except for the mufflers, i have 12" Bullets. As far as your ground clearance it will remain the same- mine did- but i think that had alot to do with shop that installed it for me. I could immediately feel the power in my high and midrange. Check out these pics, these are pictures from the shop where i had mine installed. www.not-a-sponsor.com
awesome guys appreciate the feedback. Your ground clearance stayed the same, did u have longtubes before or after the setup?
Most of the true dual setups I've seen resulted in less ground clearance. They usually remove the tunnel brace to make more room for the X-pipe, whereas the stock system goes over the tunnel brace. Also, there is not enough room in the driveline tunnel for two pipes, so they are forced to hang lower.
