My car cant be aligned?!?
So today I took my car to THREE different shops, all claiming they cant align my car. Somethings wrong with rack is what I was told. Being a v6 to v8 swap, could there be something no one knows? Is the rag/steering joint different, I was always told its the same and all of the shops confirmed this(according to them anyway). The cheapest ive found parts/labor is $505 to replace and realign. I am VERRY upset. Tell me there is something none of these shops know that is keeping this from working.....
EDIT: Just to clarify, Im using the v8 rack with the v6 rag joint which supposedly is the same.
Sorry if this is in the wrong forum, didnt really know where to put it.
my SS came with a solid steering shaft if thats what you are refering to. i stripped the end and had to find a replacement. So, all the junkyards had was V6s and they have the rubber style rag joint. well thats fine but when i got home i noticed that they will in fact fit except when you install one it makes the steering wheel way off center. i notice when lining mine and the junkyard piece up that the ends were turned different. i actually bought two and they seemed to be turned different like they were made individually for each car. so i ended up cutting the rubber joint off and matching the configuation of my stock one and welding it back solid together exactly identical. worked like a charm.
