Relocating Oil Filter Housing on an F-Body
Old 04-24-2009, 04:22 PM
SSGun's Avatar
Default Relocating Oil Filter Housing on an F-Body
I have an '02 Camaro and I have an aftermarket oil pan (not sure what brand). When I installed my long tubes, the oil filter housing (which is also modified) would not fit. I have found a few universal relocation kits that look like they might fit. I was wondering if anyone else has ran into this problem and what you did to fix it. I'm definitely open for any and all suggestions!! Thank you in advance for your time/help!!
Old 04-25-2009, 03:07 AM
SSGun's Avatar
To The Top!! Still needin' some help!!
Old 04-26-2009, 12:49 PM
SSGun's Avatar
tttttttttt
Old 04-26-2009, 01:06 PM
jrpimp00's Avatar
Got any pics of your pan?
Old 04-27-2009, 10:42 PM
SSGun's Avatar
This is the best I can do right now. In the first pic you can see how the housing mounted on the block before the header install. The other pic shows the pan a little better. It's a Moroso filter housing but I'm not real sure about the pan itself.
Attached Thumbnails Relocating Oil Filter Housing on an F-Body-408-swap-14-.jpg   Relocating Oil Filter Housing on an F-Body-408-swap-16-.jpg
Quick Reply: Relocating Oil Filter Housing on an F-Body
