SES code..
SES code..
A while back I did my longtubes and a buddy deleted the codes and all was good. Now maybe 6-7 months ago, I swapped intakes and put the ls6 on. No codes were on until the 2nd following day I drove to work in the rain. Well the next day it popped on and Az mentioned it showed the knock sensor code and o2 sensor (bank 1 sensor 2)
I finally swapped the new sensors and harness last week and again for 2 days no code but it brought up the same readings at Az.
Shouldn't the o2 sensor be deleted since a buddy deleted them from the header install? Would this trigger the ks code even if I just replaced them?
Any ideas?
Any ideas?
def check the tune....not sure why the rear sensors would trip a light if they were "deleted"
issue with the ks could be more than just the actual sensor. possibly wiring somewhere.
well why would the ks code pop on the scanner??
I don't want to take it off again and double check the wire harness only.. I put sealant around the rubber boot to prevent water from sneaking in when I drive in the rain.
