Header olts, will these work?
I seen bolts for ls1 headers that are 22mm long, I'm curious if these will work. It says LS seriers but they are 25mm long. Thanks for the help.
http://www.jegs.com/i/Percy%26%23039...21008/10002/-1
I have those same bolts and they seem to work just fine. They've been in the car for about 2 months now. One thing I should point out is that while the allen set screws keep the bolts from backing out, they also add a lot of time to retightening the bolts as you have to unscrew them before you can torque the bolt and then retighten them when done.
Oh, I put some antiseize on the inside on the pins and the allen bolt. I wanted to be absolutely sure that once they were tightened down that the pins wouldn't seize in there. It would really suck if they did because it'd be very hard to get them out.
