Is this how I should flush it?
I am going to flush my cooling system after work tonight. I was wondering what the best way to flush the system would be. I am tossed up between two methods.
Method 1:
-Open petcock
-Remove T-stat from housing
-Insert garden hose to radiator
-Start car and wait till clear water comes out of the drain.
Method 2:
-Use prestone flush kit (after I figure out how to use it)
Has anyone used the prestone kit? Is there another method that anyone want to suggest?
Method 1:
-Open petcock
Method 2:
Your t-stat IS the housing. It's all one piece (unless you have an LS2 WP). I agree with everything except removing the t-stat.
To use the Prestone cleaner, first do your Method 1, then fill the radiator with the flush kit. Then repeat Method 1. Then refill cooling system - make sure you watch your temp. gauge on first startup after the refill. If there's air in the system, it will start to overheat. Bleed it if you have to by opening the line right underneath the TB with the car running.
Hope this helps and good luck.
