LQ4 problem
LQ4 problem
alrighty i am haing a small issue with my LQ4 install. the motor came from a 2500 chevy that was equipped with an oil cooler. it has this hole in the side of the motor that the hoses for the oil cooler connect to. the oil pan doesnt seem to cover these holes and i do not want to block these off becasue i dont want to starve my motor. anyone here have a remedy for it? like a block off kit or re-route kit? i will try to get pics up later. i havent taken my F Body oil pan off the motor to see if it covers these holes but it doesnt seem likely. any suggestions? thanks
do not make a block off plate as it will starve motor of oil. just take the peice off your stock oil pan or you are going to have to use stock oil pan anyways.(you are talking about the holes right above the oil filter correct?)
