Solid motor mounts VS Knock sensors??
Old 06-08-2009, 06:51 PM
00SS6spd's Avatar
Default Solid motor mounts VS Knock sensors??
I'm building a new motor for my car, I currently have Polyurethane motor mounts. The new motor is going to be a bit beefier and I'd like to step up to solid motor mounts. However when I mentioned it to a friend of mine, he brought up the issue of triggering the knock sensors. I'm going to be running YT Ultralite rockers as well which I know can be a bit noisy... So my question to you all is do you think the solid mounts would cause me any issues?
Thanks guys!
Old 06-08-2009, 11:45 PM
180ls1's Avatar
good question, i have no idea but i have never seen a thread or someone saying that their solid motor mounts were giving their knock sensors problems
Old 06-09-2009, 12:25 AM
00SS6spd's Avatar
I don't think the mounts themselves would either... But my concern is that it's going to be a combination of the solid mounts which will cause more noise/vibration, Yella Terra Ultralite rockers which also cause more noise/vibration, and an aggressive motor. Again I don't THINK I'd have a problem... But I don't wanna shell out a few hundred dollars for solid mounts to get better power/performance, just to have the knock sensors yank timing and ruin everything.
Old 06-09-2009, 01:31 AM
Frost's Avatar
It's not any kind of issue at all.
FWIW, it's also hard to tell the difference in-car between polys and solids.
Old 06-09-2009, 03:14 AM
00SS6spd's Avatar
Thanks
Old 06-09-2009, 06:50 AM
FST SS's Avatar
no problems with my solids. they made the car feel tighter.
Quick Reply: Solid motor mounts VS Knock sensors??
