Installing Autometer shift lite
The module will be behind my center dash piece, so thats where I will tap into everything. Whats a good bolt to ground to around there? Anyone done this already and want to give me some hints?
Bad Andy
Bad Andy
i assume youre going to take the off the panel underneath the steering wheel ?? if so look under there, there are a few good places, i just used a bolt that attached to the firewall, loosened it up, wrapped the ground wire around it, and tighened it back down, you'll see what i mean when you get under there
Actually, The box is going to sit right underneath the Radio and all that crap in the center of the car. Do I need to run anything over to the bundle under the wheel or can't I tap into it from the center dash?
