ls2 intake help on 99 t/a
Old 07-11-2009, 09:32 PM
charlie97z28's Avatar
Default ls2 intake help on 99 t/a
we have the ls2 intake installed all sensors relocated and the fast throttle body hooked up we had a major vaccum leak and found the ls1 injectors wont seat on the ls2 intake what injectors will work on the ls2 intake and ls1 fuel rails or how big of a deal is converting to ls2 injectors and what will need changing
LS1-NAVY's Avatar
there is a couple things you need to swap let me search and i will post it for u
Old 07-11-2009, 09:37 PM
2000SS1979's Avatar
I dont think you have to swap injectors only the O-rings. use ls2 O-rings and it should seat.
Old 07-11-2009, 09:41 PM
are the injector holes jus smaller or what we tried soem ford racing injectors and it was the same as ls1 injectors also how many pounds are ls1 injectors
