LS Flexplate spacer bolts????
Old 07-20-2009, 06:25 AM
IMAGINEER's Avatar
Default LS Flexplate spacer bolts????
I am swapping an LQ9 into my rock buggy. I am running a 700r4 so I need to run a the GM spacer. I have searched around and I found Gm part number
12563533 which should be the correct flexplate bolts for use with the flexplate spacer. Does anyone know the underhead length for this bolt?
I googled that part number and I found a few links, one of which is to summit racing. Thre spec sheet has bolt length as .880 under head length. This is the same length as the bolt that is used with out the spacer. That doesn't seem right??
Thanks,
-Lucas
Quick Reply: LS Flexplate spacer bolts????
