Which Line Goes Where?
Old 07-22-2009, 09:15 AM
yyz28's Avatar
Thumbs up Which Line Goes Where?
If someone with an F-body could go take a look at your car and respond back. On the passenger side of the radiator, there are two small lines that come into a couple of ports at the top of the radiator, one about 3 inches from the top and one right by the radiator cap. These lines go to the cooling line between the heads (or the throttle body, if you haven't done the bypass) and the other feeds the overflow tank I believe.
My question is, which one goes where on the radiator. I THINK it is overflow tank is the top connection, TB/Head Cross over line goes to the lower port on the radiator, but I'm not 100%.
I've had the car torn apart for some time and just stuffed a new motor in it and this is the last thing I have to do before I fire it up. Just want to get it right.
Thanks!
Old 07-22-2009, 09:22 AM
Spd-Kilz's Avatar
Overflow is the top
Old 07-22-2009, 09:23 AM
blkdkz28's Avatar
you got it right the overflow is the top one
Old 07-22-2009, 10:21 AM
yyz28's Avatar
Thanks guys. That's what I thought.
