Anyone try this exhaust set up?
Has anyone used two mufflers behind the axle similar to GMMG but using something else? I have a WS6 so I want to keep the rear facia filled with two pipes, so I was thinking doing something like this. 3" to 4" Y pipe with 4" over the axle to another Y then into two seperate mufflers. One on each side so they would have to be small.....Borla stingers maybe? Something that is quiet.
What do ya think?
What do ya think?
what did you find that was small enough?
I just found Speed Inc offers a True Dual setup. Its basically what I was thinking of.
Does anyone know what this sounds like with the ATR Pitbulls?
The Pitbulls are about the only option. Basically, I didn't find small enough. Bullets fit but were pretty loud under WOT. If you found a round muffler, like 5" or maaaybe 6" it would work also. I had no idea where to get the Pitbulls from originally, and I assume they're fairly expensive. What I'd try and do is find a box or can or some object that can be made to be nearly the exact dimensions of the muffler, and play around with it to see if it'll fit to your satisfaction.
here's A PITBULL SOUND CLIP http://www.exhaustsoundclips.com/sou...p_headers.html
BEST SOUND I'VE EVER HERE ON THE NETANYWAYS.THE ONLY THING BETTER THAN GMMG IN MY OPINION.
I'VE LOOKED AND LOOKED BUT CAN'T FIND WHERE TO BUY THE MUFFLERS ANYONE ELSE KNOW.
