SLP vs. Granatelli MAF
What's the difference between these two MAFs and why is the Granatelli MAF so much more expensive? Is one really better than the other?
SLP is a bigger diameter MAF with stock tuning. No value IMO until you have heads/cam/headers.
The GMAF is stock diameter (~ported ends) but its tuning generally causes it to run lean. Because our cars are often a bit rich, you may gain a few HP from having the MAF and running leaner. If you car is not rich, there will be little or no gain. I would not use a GMAF on a nitrous car.
