LS6 catch can setup??
Well Im using the ls6 valley cover on my turbo ls1. Here is what Im planning to do lets see what you think.
Run a -6an line to both valve covers from catch can.
Run a -6 an line from catch can to vented valley cover.
those three lines above all go into the 3way block on one port on catchcan.
Then on the last port run -8 line to the turbo inlet at rear of car for vacuum. and put a t-fitting in near catch can and run a 8 an line to where stock pcv goes into intake. I will put a check valve on both lines running for the vaccuum
Think this will work?
