TPS issues... While driving, push pedal down, no change in RPM!!!
Old 09-10-2009, 04:28 AM
6LITEREATER's Avatar
Default TPS issues... While driving, push pedal down, no change in RPM!!!
Ok, so I noticed this a YEAR ago. After we installed the cam (F13), car ran fine BUT we had cracked a condensor line so no A/C.
Cruised it for a month, NO ISSUES, got A/C recharged and suddenly with A/C on (RANDOM AND INTERMITTENTLY) I would give the car gas and it would be NON-RESPONSIVE.
If I manually drop it form Overdrive to Drive it would wake back up...
Well, A/C compressor goes out. I drive it for a year, NO ISSUES.
Get the A/C fixed, issues again. May not be related but WEIRD.
SO, both times (a year ago and now) it eventually threw TPS code. I replaced with new TPS sensor (both times) BUT problem is still there and SES light randomly comes on and off (again, TPS code).
What should I look for? Messed up wire? Tune (I know tune changes when A/C is on)? Any ideas? I searched and it did not help... Thanks.
Old 09-10-2009, 10:18 AM
Frost's Avatar
What SPECIFIC number is the code that it threw for TPS?
