Could someone tell me why these are on my car?
So, last week I was changing my oil (by the way, autozone on 60 in Brandon sells German Castrol), and I was inspecting my exhaust while she was on the rack. I noticed my rear O2 sensors weren't connected to anything. I found the harnesses, and they have sims connected to them. I have stock manifolds, and what looks like a Flowmaster cat-back (no logos stamped anywhere). The only thing I can think of is that one or both O2 sensors went out, and the PO decided it was cheaper to get the sims than replacing the bad sensors. Any thoughts?
sounds like he had longtubes in the past. or he had a problem with the rear o2 sensors and did it that way since it was cheaper.
or what i believe he might have gutted the cats!
The rear 02 sensors or pointless anyway, I wouldn't worry, you can just have them deleted from your computer and not even need the sims. Before I swapped my heads and cam and got my car tuned I just found someone with ls1 edit and had them remove the skip shift and the 02 and some other minor things that took all of 15 mins.
