Can fiberglass be used to repair...
Restricted User
A nylon Intake? I know that some plastics are not good to use with things like super glue and stuff. Have a lil problem with my intake and need to know if I can use fiberglass to repair it? Or if not, then whats recommended?
Thanks,
Charlie.
Thanks,
Charlie.
Restricted User
The vacuum module in the rear ended breaking off the bottoming out tabs in the intake, causing the vacuum connector to "fall" into the intake. A friend suggested JB Weld, he used it on one and no problems so I will try that. Should just get an LS6 intake already!
i would really doubt that fibreglass would stick to plastic. if i were you i think id just bite the bullet and get the ls6 intake you kno youl want something better later anyway
