cant find a pcv on my camaro
Old 10-30-2009, 06:26 PM
kirbyman03's Avatar
Default cant find a pcv on my camaro
help, sounds stupid but cant find pcv where it supposed to be. disconnected line from front of intake no pcv followed line all the way behind engine to where it connects to back drivers side valve cover no pcv,this does have a slp ls6 intake if that helps. i work at gm dealership pulled up schematic in parts dept. and it shows pcv for 98 camaro going in to black plug in rear of drivers side valve cover, could be inside of that plug i cant get it to pull out of valve cover yet to check any help would be good
Old 10-30-2009, 08:48 PM
9911UZ28's Avatar
on my 99 #3 in the schematic is the PCV.
Old 10-30-2009, 09:00 PM
kirbyman03's Avatar
thats what i thought its not there matter of fact the mounting part of hose where valve goes in and is supposed to have some kind of cable from hose to block is not there either
Old 10-31-2009, 08:44 AM
9911UZ28's Avatar
here is a pic of a LS6 Intake PCV system I found.
