Help no heat
Help no heat
dose anyone here know where the heater control valve is located in a 98 Trans am, or what it looks like? I have been trying to fix my heater because it will not blow hot air, itblows cold ALL the time. I have replaced the thermostat in my car thinking that it was the cause of my heater problem but it was not the culprit so my next step it to find that HCV but I cant find. If anyone could help me it would be great cause I going to be a COLD WEEK for me if I cant fix it.
Thanks
Thanks
if i remember right. there is a cable that goes from the temp *** to the cold/hot door. you should be able to get to it if you remove the kick pannel under the glove box its close to the blower motor.
I stand corrected, the hot/cold door is cable operated, the bi-level doors are vacuum operated.
(I should have remembered this as I have dealt with it several times before...:doh:
Sorry for no pics, they just wouldn't load........ this is from alldata... You should be able to follow the cable from the back of the control **** to the other end where it controls the door.
1998 Pontiac Firebird V8-5.7L VIN G
Vehicle Level Heating and Air Conditioning Air Door Air Door Cable Service and Repair
Service and Repair
Notes
Remove or Disconnect
Right instrument panel insulator.
Temperature control cable at A/C module (1).
Remove temperature control cable bolt.
Accessory trim plate.
Pull control cable trim plate rearward and off instrument panel lower trim pad.
HVAC control bolts.
HVAC control.
Pull control out far enough to reach temperature control cable connection.
Temperature control cable.
While releasing temperature control cable clips from control, pry temperature control cable with small screwdriver from control.
Install or Connect
Temperature control cable to control.
Slip temperature control cable into position over lever arm. Align shaft with temperature control cable slot.
Press temperature control cable clip into slot in control. Make sure all three clips are in place.
HVAC control.
HVAC control bolts. Tighten
HVAC control bolts to 1.9 N.m (17 lb. in.) .
Hold accessory trim plate in position and press it forward to engage four retaining clips.
Temperature control cable at heater module with temperature control cable bolt. Tighten
Temperature control cable bolt to 1.9 N.m (17 lb. in.) .
Service and Repair
Notes
HVAC control bolts.
HVAC control.
Install or Connect
HVAC control.
