ARP Header bolts
On an LS1...? No, you need metric bolts: M8x1.25x20 or M8x1.25x25 depending on header flange thickness.
In ARP catalog, on page 81, see these part #'s:
661-1001, 671-1001, 761-1001, 771-1001.
661-1002, 671-1002, 761-1002, 771-1002.
You should measure the hole depth first (including header flange), you do not want the bolts to bottom out in the holes.
Hole depth is threaded to 16mm, and typically on good headers the flanges are 10mm or thicker.
