Carb conversion questions..HELP!
I recently bought a salvaged '05 silverado 5.3 that will be going in an '86 shortbed. I'm wanting to convert to Carb for multiple reasons.
The truck will mainly be a cruiser but optimizing the power output is also wanted.
I plan on keeping everything about the engine stock.
I have a few questions that maybe some experienced folks could answer.
I'm wanting to keep the stock coil packs in lieu of a distrubutor. Which MSD ignition should i go with....the one with the 6 preprogrammed "pills" or the one that cab be adjusted with a labtop? Keep in mind the motor will be stock...no power adders, or internal work.
Also what carb have you guys gone with for a near stock application?
Thanks
Thanks
I have an '05 6.0 and will be purchasing the 6010. You can use pills or program with a laptop...it is the best of both worlds.
A 600 carb will be more than enough for a stock-ish 5.3.
