Can I switch the rear pieces of other SLP exhaust with Loudmouth?
I have electronic cutouts now so I dont car if my exhaust is restrictive, I would like to replace the rear section of my loudmouth with other SLP Muffler exhaust. The reason I want to keep the Loudmouth I pipe in is because I had to shorten it and I had a Dynomax welded into it. So basically does any 2 SLP exhaust systems use the same I pipe??
Yes, SLP 'I' pipes are the same, I have switched back & forth with LM , dual/dual/, & 2OTL 'I' pipes.... dual/dual & 2OTL have the same part # for 'I' pipe. The LM 'I' pipe is terminated, ends, where it meets the over-the-axle pipe, in the same spot as the others..
Dave
Dave
