Is a open Borla exhaust close to as good as a cut-out?
STF Veteran
It seems like the Borla with no plates in it would serve the same purpose as a cut out. Isn't it a cut-out in itself? Am I missing something here?
STF Veteran
I don't understand how there couldn't be a difference. If that is the case then why do people run cut-outs? I thought that the point of a cut-out was to let the exhaust gases escape faster and less restricted. With that logic, there is now way that the exhaust gases don't escape any faster with the largest opened plate than they do with the closed plate and traveling through a muffler.
Originally Posted by Redlinez
According to Paul at Thunder Racing there is no real difference between the solid plate and the big hole plate. I never noticed any difference at the track. Just sound.
thats not true
I bet some cars with run faster with a solid plate and some will run faster with no plate....just depends on the setup. But there is a difference
and I think an open borla is just as good as a cutout, but i think it sounds better, and probably has better back pressure
Originally Posted by SouthFL.02.SS
Here we go with the back pressure thing...
tell it to the dyno
Originally Posted by 02redSS
The least amount of back pressure is the best. Why do you think all the big racers run open headers? If mufflers made more HP wouldn't they all have them?
tell it to the dyno... again...
http://home.att.net/~carlos.ramirez1...2/site1003.jpg
Originally Posted by JoeT/A
Your talking about a couple horsepower. That could be because the air temp changed, or the motor was slightly cooler when it was run. 1 to 2 HP on a dyno is consistant, you can't say that one is better than another.
it all depends what kind of power band you want....
my friend just put LT's on his car...he has borla and a cutout. He says it sucks driving with the cutout open now because the car has nothing down low....why? a little thing called back pressure.
but wait, we're all hardcore drag racers that care nothing about power bands right? take your cutout and peak numbers, i'll run my borla and take my torque
btw- Aren't you supposed to be working?!?
My cutout is under the passengers seat about 1 foot behind the Y pipe. with the Mac headers and Y-pipe being 2.5 inch , I gain 18 hp over my Edelbrock catback with heads and cam. THe power is from off Idle to redline. I gain 2mph at the track with open cutout.
I love the tone of the cat back though and works great on the street for not giving away that the car is not stock unless you are up close. A car on the side of me usually thinks its a stock T/A
