LS6 intake Opening diamiter?
Old 12-15-2009, 06:14 PM
82cetuner's Avatar
Default LS6 intake Opening diamiter?
does anyone know what the stock LS6 intake opening diameter is?
Old 12-15-2009, 06:19 PM
twitchtwice's Avatar
78mm. same as the ls1
Old 12-15-2009, 11:01 PM
sinful7's Avatar
i think you can port it to 80mm, and i also heard of some company being able to mate a 90mm ls2 opening on a ls6 intake so you can run a 90mm throttle body... I guess its not far off a fast 90. but i couldnt tell ya who does it.
Old 12-16-2009, 12:21 AM
mknight759's Avatar
here it is http://www.tpis.com/index.php?module...ed+LS6+Intakes
Old 12-16-2009, 06:15 AM
toadzq8's Avatar
I measured my LS6 with calipers and it is 75mm, using a 78mm fast TB you can feel the lip. Not a lot of plastic in between the seal o-ring and the ID don't think I would try to port unless you know what your doing,
Quick Reply: LS6 intake Opening diamiter?
