PCM ignition 1 feed ???????????
I removed all my harness and organized it, when i re-installed it. the car would'nt start. I checked every single wire, and it is connected correctly. Except for the pink wire on Pin 19 on the blue connector. It is the PCM ignition 1 Feed. Now where does this go ? I have no clue. I checked the spark plugs wiring, and there is no spark. So i think it is because this wire is not connected. help!!
