ls6 pcv
ls6 pcv
hey guys quick question. how does this work when you convert to the ls6 vally cover...just plug the holes in the valve covers? im going to switch to the ls6 vally cover and a catch can set up.....also needing a catch can and ls6 vally cover thanks
Have you seen this writeup:
http://www.ls1howto.com/index.php?article=18
I connected the rear ports on the valve covers together with a vacuum hose, didn't use the plug like they did in the link above. And the front port on the passenger valve cover still needs fresh air from the throttle body.
