TCS/Cruise Delete
http://www.summitracing.com/parts/LOK-TC-1000LS148/
this is the one I used. Its a little long and needed to be cut down so it wouldn't flap around. If you don't want to cut it, you could probably route it around the intake to get rid of the slack. thats the way I think it was meant to be installed.
i thought removing TCS on a TCS car would trigger the ABS not to work properly? TCS is a 4-channel rear (reluctor rings on each wheel) while a non-TCS car is a 3-channel (3 sensors total, sensors on both fronts and one sensor on the ring gear)
just thought id throw that in for consideration
Hope this helps:
Sorry about the delay. This was pretty cool, cuz I actually need most of these parts too
1. Throttle cable:
3. Starter:
6. IAC kit (includs IAC and oring) : 17113391
7. Throttle cable bracket : 12552278
there is also another throttle cable bracket which gets mounted on the rear drivers side fule rail stud:
8.Bracket: 12552865
1. Throttle cable:
98-99 Cable, LS1 (EXEC NW9) 12565559
98-99 Cable, LS1 (NW9) 12552267
00-02 Cable, LS1 (EXEC NW9) 12565560
00-02 Cable, LS1 (NW9) 12563651
NW9 = Traction control
2. Flexplate: 1255305498-99 Cable, LS1 (NW9) 12552267
3. Starter:
98-01: 10455385
02: 10465547
starter bolts:
4. Engine Mount:02: 10465547
starter bolts:
Outboard bolt (M10x1.5x113):
98: 12558858
99-02 (zinc): 12561387
Inboard bolt: (M10x1.5x46): 99-02 (zinc): 12561387
98: 12555160
99-02 (zinc): 12561848
98-99 (qty 2 required) 22174968
00-02 (qty 2 required) 22179268
5. TPS Kit (includs TPS and oring) : 1712358200-02 (qty 2 required) 22179268
8.Bracket: 12552865
