mystery missfire in cylinder 6
Old 02-15-2010, 04:46 PM
Yuik87's Avatar
Default mystery missfire in cylinder 6
OK here it goes i have a slight miss thats noticable at idle and can be seen
on a scanner so i tried swapping wires they are msd and nothin then i put in
a new plug then swapped injectors then coil packs and the problem never
moved or changed i checked compression for the hell of it and it was at 125
hooked up a vaccum gauge to the car and it was steady so im out of ideas
the only thing i can think of is that the scanner is reading the wrong cylinder
because i read on here somewhere that some scanners mix up cylinders 6
and 8 but other than that im dry
Old 02-16-2010, 01:16 AM
uphigh07's Avatar
try swapping the coil it is what produces the spark in the first place.
Old 02-16-2010, 03:12 PM
Yuik87's Avatar
i already swapped the coil pack. Has anyone heard of the scanner showing wrong cylinder miss because i know i saw something about it on here
Old 02-17-2010, 03:18 PM
Yuik87's Avatar
anyone????
