I broke this hose. What is it?
Well, I went to go take out my intake today to put some loctite on my Oil Pressure Sensor (which I just found out is broken), and I broke the small hose in the back of the intake that goes to the AC. Does anyone know what this piece is called so I can order it from the dealer?
Here's the pics of it:
http://pbckt.com/sZ.dfQV
Vacuum Tube
I believe it is the rubber vacuum tube for the HVAC system.
It goes on the back side of the intake just under the MAP sensor.
You will need to make sure you have this fixed and attached to the back side of the intake otherwise you will have a vacuum leak in addition to the oil pressure sensor.
you can get small rubber vacuum hose from almost any parts house auto zone, pep boys, etc...
See the attachment; I circled it in red where it attaches to the intake.
Good luck.
Good luck.
