Trick to injector install?
Old 06-15-2010, 07:35 PM
Y2K WS6's Avatar
Default Trick to injector install?
I am having one hell of a time getting the fuel rails re-installed in my 1998 LS1 is there any tips or tricks you guys can give me. I can't seem to get the back injectors to seat...
I tried a search, but got everything but the answer.
the intake is ON the engine, I haven't needed to take it off Just have to upgrade injectors because of the turbo.
Old 06-15-2010, 09:52 PM
jerflash's Avatar
they should just pop in man with no trouble at all...i would look to see if your using the right height injectors as stok cause they do may different sizes...or maybe you installed them incorrectly
Old 06-15-2010, 10:52 PM
conor.davis's Avatar
Mine didnt make the pop noise nor did I "feel" them seat in after I put them in...
I just put dielectric grease on them and bolted the rails on and everything is working fine.
Old 06-16-2010, 12:29 AM
flintwrench69's Avatar
Spray some carb or throttle body cleaner on the o-rings right before you set the rail in place. Works better than grease IMO.
Old 06-16-2010, 02:50 AM
99T/A_Marine's Avatar
Rub some vaseline on the o-rings. Only a small amount and they will slip right in. No pun intended.
Old 06-16-2010, 02:53 AM
00MaroonZ28's Avatar
+1. Just be careful not to get any on the nozzle of the fuel injector.
Quick Reply: Trick to injector install?
