CTS-V power steering pump line
I'm in the last stages of swapping an LS6 into my 2000 Silverado. I got the CTS-V accessory drive and I'm wondering if someone makes a fitting that goes into the pump for the pressure line (quick connect) that has a female on the other end to put my original pressure line in which is the metric line with the seal on the end of the line. I took the adapter out of the pump, it's the same size threads as my pressure line, but different style sealing system. Trying to figure out the easiest way to do this. Thanks!
