TH350 behind my LS1 engine
I have a built TH350 that has been sitting behind my buddies shop since 05 when I swapped it out of my LT1 for a T56. It bolted right up to the LT1, I believe I used the B&M kit that gave me a torque arm mount and I bought a MadMan dipstick for it.
First of all what are the odds it is still good, I believe it was put out there with the dipstick tube installed and the converter mounted, but there is a possibility that water and/or gunk has gotten in there. Any tips here, it was a good build when it was pulled.
Secondly, what is required to bolt this to an LS1? It's got a 3.5k TCI stall converter but I think I remember hearing that you have to run some type of adapter? Also, in the LT1 the stock shifter/cable worked, not sure about LS1.
Thanks!
Thanks!
Location: Your girl's back door giving her the long stroke while you're at work
Pull the pan off it and see what the fluid looks like, you can also get rebuild kits cheap
https://ls1tech.com/forums/automatic...questions.html
https://ls1tech.com/forums/automatic...th400-faq.html
Well, I have a 9inch tailshaft Th350. So I know I can use the stock driveshaft. I have an A4 crossmember (looks like I'll have to get that modified).
My question is I have the stock A4 flexplate, will my th350 converter bolt up, do I need to use a spacer, etc.
The 98 model flexplate works and I think the 6.0 one does. I'm running the TCI piece on my car
You will have to run a spacer
I don't know if that will work or not, you might have a mod move this to the Auto trans section and you might get more answers
