Lower gas pedal height after fast 90mm intake install
Old 08-01-2010, 07:35 PM
CamaroSS1618's Avatar
Default Lower gas pedal height after fast 90mm intake install
After installing my fast 90 mm intake the gas pedal has lowered in height or pushed closer to the floor. I believe this is the case because the fast intake and fast TB are a little longer than the stock setup. This bothers me because the throttle is too sensitive. How can I raise the pedal to align with the brake and clutch? Longer TB cable or a new pedals?
Pics:
Thanks for your help
Old 08-01-2010, 08:58 PM
99SSJarhead's Avatar
If you follow your throttle cable from the throttle body you should find a piece that can be opened that allows you to adjust the cable tighter or looser. Just loosen it a bit and you should be fine.
At least this is how my 99 is.
Old 08-01-2010, 09:35 PM
KRAZY K 2000 TA's Avatar
did you check to see if it is still even opening up 100%
Old 08-01-2010, 10:11 PM
180ls1's Avatar
good idea
Old 08-01-2010, 11:09 PM
I will check the throttle position when the pedal should be WOT.
I followed the throttle cable but it goes straight to the firewall, there is nothing to adjust. I don't have traction control on the car, maybe that is why there is no adjuster. It seems like the cable is too long because when I bring the pedal to normal height there is a lot of lag in the cable at the TB. Can I cut the cable and re-attach the TB hook or stopper thing?
Old 08-01-2010, 11:17 PM
Just checked, tt opens to about 98%. If I can raise the pedal i can reach 100%.
