manual fan switches?
I read a write up once that used leds and a 3 way switch and blah blah blah and i was wondering if there was a way i could use 2 seperate switches for high and low and if there was a way to get LEDS for them so that i can tell when they are on or not.
i dont really do create your own wiring solutions very well, but i understand how wiring is supposed to be and can fallow directions pretty well. I wanted to run two switches in an HVAC panel i made next to a few other switches i have.. They all have LEDS so ya... Anyone?
I have the SLP fan switch and wired leds to it, works even with the switch in the middle position (PCM commanded) and illuminates one on low, both on high using two separate leds. Not sure if that's what you're looking for.
