Ls6 Intake install help
what else do i need to install the Ls6 intake correctly, i heard i need some kind of vacuum lines or something.. can anyone verify this and give me any insight on what to expect on the install
ls6 install
Its pretty straight forward, I think you can find it on ls1howto.com
...but you have to get a different crossover pipe for the front and plugs to block off the rear coolant passages on the heads or you can grind the fins down on the bottom of the intake.
Get rid of your EGR somehow, and be careful not to destroy the oil pressure sensor that is right near the vacuum line at the back of the manifold that goes to the brake booster
Good luck and try a search for pics etc.
I would also like more insight on this. I've been using the search option to no avail. I came across a how to video, but it's no longer available. Can someone assist with part#s to the coolant pipes & plugs mentioned above?
Location: Your girl's back door giving her the long stroke while you're at work
