Need the size of the oil pan bolt used to drain oil. Mine snapped
Old 08-28-2010, 07:51 PM
CJDZ24_Z28's Avatar
Default Need the size of the oil pan bolt used to drain oil. Mine snapped
Yes my oil pan bolt snapped inside the oil pan when i was tightening the bolt after draining the old oil. I searched many times but cannot find the exact size of the bolt or thread pattern. Guess I'm going to get a reverse drill bit and try to get it out. Any help will be appreciated
Old 08-28-2010, 09:19 PM
98TAjwh's Avatar
you're gonna want to get the rest of that plug out of there. you can get a replacement plug at any auto store.
Old 08-29-2010, 10:03 PM
Chrome355z's Avatar
Just start w/ a small drill bit and slowly increase the size drilling it out; shouldn't be too hard.
Just call an auto parts store or a chevy dealership. They'll hook you up w/ a new drain plug.
Old 08-29-2010, 10:40 PM
NBM-LS1's Avatar
WTF! Its a drain plug man! How hard are you cranking on that bitch!?!?! LOL
If you can drill through it your home free. then use an easy out.
if not you can always try a hammer and chisel.
Old 08-30-2010, 04:45 AM
blue98Z's Avatar
Get an easy out kit. If you have a harbor freight close they sell them for around $10. It's a good thing to have incase you twist the head off another bolt. Plus its a new tool
Quick Reply: Need the size of the oil pan bolt used to drain oil. Mine snapped
